is dvd2avi the best program to turn dvd to avi? ive tried it and you have to go thru many steps, i saved the project in avi then i had to run it in tmpgenc because the video and audio were separate, i save the ausio as a wav file.. is there a program then there are less step? i couldnt get an avi file to emailfrom dvd2avi because it didnt just switch it to an avi file..,
my reason is i want to get a portion of the dvd video to email as a avi file, tried to get a good file quality to email but as i did these steps..
also what a good dvd ripper to get the dvd file to my hard drive?
is there a progran to get the dvd off the dvd to avi?
thanks
DVD Shrink and DVD Decryptor are good freeware rippers. Virtual Dub mod can convert your VOBs to AVIs.
Hello. -
does virtualdubmod do everything virtualdub does? so can i delete virtualdub from my hardrive and just keep vitualdubmod?
thanks -
Yes, I only use Virtual Dub mod now. Virtual Dub cannot load VOBs, so I have no use for it now I have the "mod".
Hello. -
When I load a VOB into Virtualdubmod and try to save as an AVI (with some codec' compression) it takes HOURS to make the conversion. On the other hand if I choose "no compression RGB" it takes only minutes but GIGANTIC file sizes.... what can I do to convert my VOBs to AVIs ?(AVIs for editing on NLE).
ImTOO DVD Ripper is a DVD converter which can convert DVD to VCD, DVD to DivX, DVD to MPEG, DVD to AVI easily and quickly with excellent image and sound quality. It's the best DVD ripping software to convert DVD and rip it. A software DVD converter which is easy to use with high ripping speed.
It cost $35.00, but has has a trial version which will convert 5 minutes of DVD to any format. You can find it at http://www.imtoo.com/
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
