  1. who knows
    Guest
    I like to be able to import a menu (in svcd2dvd) from for instante DVD Menu studio. What type of menu definition file (extension) must i use to import it in svcd2dvd?
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    You must create a new menu (using New Menu) which will launch DVD MenuMaker. You can then load a background to your menu and this background can be a bmp file exported from dvd menustudio. Use File> export bitmap from menu studio to create a suitable bmp file.
