Who do you guys think makes these. CMC? The code seems familiar, but I can't remember where I've seen it. They're Eworks. Here is the code:
Region information N/A not a DVD-VIDEO
Media code/Manufacturer ID AN32
Format Capacity Not Formatted
Free Blocks 411107328
Free Capacity 4.38GB(4.71GB)
Book Type DVD-R
Media Type DVD-R
Media Id Code Speed 4.0x 5540KBps
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.0x 2770KBps
Available Write Descriptor CLV 1.0x 1385KBps
Write Strategy Speed 4.0x 5540KBps
2x Speed OPC beta 0B
2x Speed OPC power 10
2x Write Strategy field 1 11 87 78 80
2x Write Strategy field 2 88 80 00 00 00 00
4x Speed OPC beta 06
4x Speed OPC power 17
4x Write Strategy field 1 0D 0F 0B 0B
4x Write Strategy field 2 98 08 0F 0B
4x Write Strategy field 3 00 00 00 00
4x Speed OPC beta multi-pulse 06
4x Speed OPC power multi-pulse 1C
4x Write Strategy field 4 13 A8 88 65
4x Write Strategy field 5 98 9A 88 80 00 00
4x Write Strategy field 6 00 00 D0 00 00
Data area starting sector 30000h
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
Results 1 to 9 of 9
Stick a spoon in me, they're SKY brand 4x media. Spotty record, with some standalones from what i recall mentioned here. At least they seem to burn fine on the Pioneer 105,for the most part.
I have had a great deal of success with AN31 discs - you like to think those you've got would be a bit better, right ?
I can't say I've tried those, but if you ever come across the AN31, don't let your experience of the 32's put you off trying them. You might be pleasantly surprised. -
Yeah, but I'm even too smart to fool myself. The Sky/AN32 discs have been discussed here, before. Consensus for the most part is: CRAP. I've tried samples under the SKY brand with mixed results. I'm sure the AN32 Eworks will be no better. I'll burn them at 2x, instead of 4x for hopefully better results.(First disc was good, so far) Just another case of mediocrity sold under another brand. Who knows maybe they've improved the formula before selling them as Eworks discs. Sure. -
i have burnt 125 SKY an32's at 4x with 0 problems or coasters, i have used 3 burners also, all worked at 4x, i used the TDK, the Sony, and the new Liteon
No playback issues at ALL? Out of the 10 Sky discs I burned with the Pioneer 105, three had one second hiccups toward the end of the disc. Same results on two standalones and my computer software player. -
yeah i've used these on a sony dru510a works fine at 4 X
but there crap in a lite-on ldw-411s
and there also a Laser Brand -
This disk also come under the name Sonix. Sonix with a X not a C.
They burned at 4x with my Sony and my Plextor without problem. They played fine on my Pioneer and Sony dvd player. I had MAJOR problems with them on my XBOX, PS2, and an APEX player of my friends. Disk not recognized.
Wont use again. -
Thanks. I'll try those three burned eworks discs in my PS2.
GSpot...yet to identify
By Greyhorne in forum Software PlayingReplies: 4Last Post: 16th Oct 2011, 21:53 -
Please identify this disc and how Windows can read it
By The Big Cheese in forum Newbie / General discussionsReplies: 2Last Post: 8th Jun 2009, 08:41 -
Identify what program was used
By megafree in forum DVD RippingReplies: 2Last Post: 27th Nov 2008, 17:32 -
Can someone identify this problem ?...
By JoseD in forum RestorationReplies: 6Last Post: 13th Feb 2008, 19:38 -
Identify this movie
By gadgetguy in forum Off topicReplies: 2Last Post: 27th Jul 2007, 13:37
