I currently use Clone DVD to backupmy DVD's, which works fine untill, it seems there is a lot on the DVD and then it compress every thing down and some times you lose the quality.
Therefore, I'm after your comments with the best software to use to backup DVD's - either just a straight copy or if I just want to extract the movie from the disc (no extras) .... I have seen DVD Shrink named on this site, is that any good?
Please help.
For ease of use, I'd say DVD2ONE, but DVD Shrink is quite powerful, has it's own onboard ripper, and is free to boot.
Of course, I was doing this before either of those two babies came on the scene, and have still been known on occasion to strip streams in IFOedit and, if necessary, re-encode with the likes of TMPGenc or, if I'm feeling lazy, ReMPG2.
If you use say IFOedit and strip out any streams and trailers etc that you won't need, you may be surprised how many movies fit on a DVD-/+R without further work.
BTW - DVD2ONE is bloody quick !! -
It's great for movie-only and it also allows you to specify the compression of any part of the DVD, right down to still picturesOriginally Posted by macca
the only thing it is missing is content removal while retaining functional menus
give it a try, it won't cost anything but a little time and effort
MP4s - how to correct them, then join them together?
By extent in forum Video ConversionReplies: 2Last Post: 15th Aug 2010, 15:06 -
Correct pulldown or not
By carlmart in forum Video ConversionReplies: 2Last Post: 1st Feb 2009, 19:25 -
Is there Any software that will correct for tracking errors on a DVD?
By hitechluddite in forum DVD RippingReplies: 7Last Post: 19th Jan 2009, 11:32 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 15:09 -
My OS is hooky, and I'd like to correct it.
By Will Hay in forum ComputerReplies: 15Last Post: 28th Jun 2007, 17:06
