How do you uninstall VobSub under W2K?
I installed it to try and see if it was what I needed to display subtitles in the way I wanted but have now found out that it isn't what I want afterall. I went to uninstall but there's no entry in Add/Remove Programs. I looked for an uninstall utility in the Program folder as well... nothing.
I've now deleted the entire program directory and the plug-in that was placed in the VirtualDub directory as well, then I've cleaned the registry with a dozen different utilities to try and get rid of whatever keeps displaying this green arrow in my system tray every time I watch a video, but nothing works.
Forget this. I've found what I needed to delete.
How do get rid of this 'orrible little piece of computer pollution?
Results 1 to 1 of 1
question about difficulty in uninstalling file
By jimdagys in forum ComputerReplies: 3Last Post: 28th Mar 2008, 09:52 -
Uninstalling or reinstalling nero
By b3cko in forum ComputerReplies: 3Last Post: 10th Jan 2008, 08:37 -
Uninstalling this utorrent program
By vipertongn in forum ComputerReplies: 7Last Post: 5th Aug 2007, 07:17 -
Trouble uninstalling dvd43 - help
By NitroxAZ in forum Newbie / General discussionsReplies: 1Last Post: 18th Jun 2007, 22:43 -
no audio device after uninstalling antivirus?
By Rudyard in forum ComputerReplies: 4Last Post: 23rd May 2007, 21:19
