    Jul 2003
    Cincinnati, OH, USA
    Ok here is the problem,
    I've converted a DVD into a DivX File using InterVideo DVD Copy.
    I've checked the file and it works great.
    This is actually an Anime with three episodes on the disc so I want to split them up.
    I opened the File in VirtualDubMod. Configured it according a guide on doom9.org.
    I start the selection in VDUBMOD just after the FBI Warning at a keyframe and then the file cut is at a keyframe in the credits.
    Not matter what settings I change the sounds is ALWAYS ahead of the Video. Any Settings you can reccomend I try?
    Oh yeah and Boilsoft Video Splitter has the same issue.
    Anyone have any idea about settings to try?
  2. Member tumbar's Avatar
    I also create divx files from episodic dvd's. I create a different folder for each title or episode. First I decrypt to hard drive, all files. Next I use DVDShrink to create new complete title sets, for each episode (reauthor) in each folder. Then I let InterVideo DVD Copy create the divx file at a specified size. 2 per cd = 345mg 3 per cd = 230mg
    I had trouble splitting afterward also.
    Jim
    Jul 2003
    Cincinnati, OH, USA
    I'll give this a try.
    Thanks!
