Going to buy a Pioneer A06, what's better +r or -R for data? I did a google search. It appears that the +r does not have to be finalized, is that the only difference?
Only u can decide that. Most people first check to see what their standalone will play first then go with that. Buy a few of each and fart around. I burn +R and play em in my ps2 and they work great, but will be getting a jvc svn33 for $45.00 on the base exchange come Black Friday and then Ill just buy whatever is on sale because it will play both, even though the ps2 will play both.
Thanks, I was hoping the +r would have similar attributes as dvd ram. It says that you don't have to finalize the the +r disc and can make changes anytime, does that mean it will act like hard drive? Can I add a delete data from a pc on these like ram?
I may be mistaken, but I'm pretty sure that DVD-Ram is the only format that works like a floppy. That's really the only reason that DVD-Ram is still around. I really don't think that either disk would give you a significant advantage over the other. Buy whatever's cheaper.
If you are speaking of writing over the dvd then NO. If it is a +RW then yes. +R has lossless linking
Originally Posted by jaxxboss
I'm a -R man myself and have no problems, BUT, saying that...
+R has the edge over -R on data because:
1. Better error correction (at the expense of a few Mb in size)
2. Marginally faster access times due to the way the data is organised and more reliable clocking mechanism
3. I have never seen packet writing for a -R drive
If you're using the discs for data, don't worry about standalone playability quite so much. Playing video on a standalone can be a bit of a black art, but so long as the player is +R compatible, if that data happens to be say MP3's or something your player can handle, you should be OK.
Pioneer DVR-510H-S GGV1179 data disc download
By viperss in forum DVD & Blu-ray RecordersReplies: 31Last Post: 30th Mar 2021, 08:57 -
Pioneer dvr-450h data service disc
By A/VPHREAK in forum DVD & Blu-ray RecordersReplies: 1Last Post: 9th Jul 2010, 16:14 -
Would anyone still buy a Pioneer Kuro panel ?
By Seeker47 in forum DVB / IPTVReplies: 24Last Post: 29th Nov 2009, 17:25 -
Which DVD Recorder to buy, Pioneer?
By J C in forum DVD & Blu-ray RecordersReplies: 71Last Post: 4th Jul 2007, 10:22 -
Pioneer 420H - Can't Write Data Error
By cie3 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 23rd May 2007, 22:51
