    Oct 2003
    Canada
    How do you rip the movie only and then reencode it with Cinema craft encoder so that it would fit on a DVDR and then burn it while keeping the original menu of the original DVD movie? So that means after you encode the movie, you put it on the new DVDR with the original menu.
  2. lotsa guides on your left side...good luck (you'll definitely need it )
