Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I have had Vegas 4.0 for a while but never installed the DVD Architect part of it, in fact I forgot about it until today. I was thinking about buying svcd2dvd today, but found out I might not need it...
    I read a tutorial on dvd architect that said you can take your svcd and use isobuster to extract the .mpg... then you just import it into dvd architect and it will author, encode, and burn your dvd all in one easy program...
    I am not trying to talk anyone out of using svcd2dvd, I would just like to know if I can use dvd architect and not buy extra software (vegas+dvd architect was a lot of money after all)...
    So, does anyone know if this will do what I want it to, if not, what are the drawbacks? Thanks
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Just try it & let us know if it works
