Hi all - I have tried a few of the things I found in this forum, but none of the threads I found seemed to help
I have the following AVI:
576x320 / 23.976 fps / XviD MPEG-4 Codec / 48000Hz Audio @ MPEG Layer-3 Codec (professional)
I can play it without any errors or problems on my machine. However - when I try to encode it to an mpg to create a DVD from it (using TMPGEnc Plus 2.513.53.162) the preview-screen stays black during encoding and - surprise, surprise - I end up with an mpeg where the sound is all there but the picture is one long boring piece of .... you guessed it... BLACK! Argh! I set up the template using the Project Wiz. in TMPGEnc and it has worked fine for me sofar - I am guessing this is a codec problem - but how come I can watch the movie in WMP but can't encode it to mpeg2.
Also - another thing I have noticed - even if I select "film" in the wizard whilst encoding for a DVD, TMPGEnc displays "29.7fps" in the settings bar underneath the output file location.... is this normal? I can't change it manually unfortunately
Help appriciated!![]()
I think I found the solution...try this (worked for me)
1) Open TMPGEnc and press Cancel if Wizard pops up
2) Go to Option->Environmental Setting...->VFAPI plug-in
3) Adjust the plug-in priorities (this is done by right clicking on
the plug-in and choosing Higher priority as many times as
necessary) to match the following:
DirectShow Multimedia File Reader.......3
AVI2(OpenDML) File Reader................1
AVI VFW compatibility Reader.............0
CyberLink MPEG-2 Decoder.................0
Microsoft MPEG-1 Decoder.................0
Wave File Reader..............................0
BMP/PPM/TGA/JPG File Reader...........-2
DVD2AVI Project File Reader 1.76+.....-2*
TMPGEnc Project File Reader 2.58......-2*
4) Press OK
5) Now you can load your XviD AVI into TMPGEnc just like any other
AVI and encode as you wish. -
Hi again - have tried and failed
Still getting the black screen whilst attempting to encode.
Also - any ideas about the framerate issue?
Thx for your help sofar! -
Hi...
It's gotta be the codec then...as far as I know about this stuff (I'm a newbie too..don't you forget it
Try to get the DivX codec at :
http://www.divx-digest.com/software/xvid.html
Install it and let me know...
Hooky
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 10:30 -
How to put black colour on screen without re-encoding?
By swalih in forum EditingReplies: 6Last Post: 16th Feb 2012, 04:44 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
Black Screen
By jansz in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2008, 12:03 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
