Hello!
I have bought a double sided DVD a long time ago and now I would like to put both sides of the DVD to one DVD-R preserving the menus and everything. Each side is roughly 3 gigs in size so I can shrink them down to 2.2 gigs easily with DVD-Shrink or something. Now the problem is that I can't join both sides. Most programs with join options just join the main movie but do not allow to use the menus. Does anybody know how I can join everything together Movie, Menus etc?
flobbo
take resultant joined movie and input into TMPGEnc DVD Author or DVDLab to generate new menus and chapters. then burn output internally, or with another prog. good luck.
New to double sided dvd's - Burning Hi Quality Media Files
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2012, 21:50 -
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 16:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 22:23 -
do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 11:40 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 05:04
