Hi, this is my first post and I am a newbie. My question is, when I'm burning avi's to vcd in windvd, alot of times towards the very end or at the very end of burning, it says error: can not complete burning process. When this happens is there something wrong with one or more of the avi's? or could it be the tdk media i use is inconsistent? I have no clue, I hope someone can please help. thanks
It could be a number of things. I'm not familiar with windvd and how it makes files.
You can't get more than 80 minutes of video onto a CDR doing VCD's. Any more and it will fail. If you have a bunch of smaller files, then there's overhead to consider, you may wnat to shoot for 75 minutes of video.
Are you sure you have 700 MB CDR's and not 640's?
Waht are you using to burn with?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I am using nec 1300 dvd burner, and i don't go over the 700mb. it works some of the time.
Subtitles not complete
By Antares in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th May 2011, 11:26 -
Saving DVD Disc Image for someone else to burn complete with autoplay&loop?
By wyclef in forum Authoring (DVD)Replies: 4Last Post: 11th Jun 2010, 00:07 -
Does SVCD2DVD process and burn HD quality DVD from HD .ts file?
By jeemak in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Nov 2008, 23:03 -
New DVD writer... Burn process failed at 2x (2,770 KB/s)
By planetx in forum DVD & Blu-ray WritersReplies: 8Last Post: 8th Feb 2008, 16:40 -
nero - dvd burn failure - no seek complete error
By rock in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 15:28
