  1. Hi there.
    I have the following problem.
    After I use DVD2AVI to make the VOB files appear as mp2, I run VFAPI codec to make a "fake" AVI ile in order to edit it in VDub and then frameserve to TMPGEnc.
    However, when I try to open the VFAPI avi in VirtualDub, it gives me the following error : "Cannot determine filrtype of xxxxx.avi "
    I know I have installed the VFAPI codec properly and have also run the vifpset.bat after installing, however the problem persists.
    What am I doing wrong ?
    Thx in advance.
    P.S. : Windows Media Player cannot open the VFAPI avi either, giving me an "unsupported filetype error"
  2. Well, I am sure that a previous VFAPI avi worked with VDub. Then I frameserved and when I tried to open VFAPI again, I couldn't.
    I now read from posts that frameserver has to be turned off, however at that time I didn't know that and i uninstalled VDub, withoud disabling frameserve.
    After I installed VDub again, I run the proxyoff.reg (to turn frameserve off), however the problem persisted there.
    What alterations does the frameserve option do to my system and how can I bring my system back to what it was before frameserving ? (proxyoff.reg doesn't seem to work)
    Thx in advance.
  3. WELL I FIXED IT !!!!!
    Seems like you have to re-encode from d2v--->VFAPI avi after disabling frameserving in VDUB.
    I just kept on trying to load a VFAPI avi hat was created while frameserving was still "on" and nothing happened.
    Just keep that in mind guys : "DISABLE FRAMESERVE IMMEDIATELY AFTER YOU STOP FRAMESEVING"
    See ya.
    Australia
    Could I use a similar method so LSX MPEG encoder can recognise the DVD2AVI output files (.d2v extensions?) as I get a similar 'not an avi or unrecognised format' type error? Ultimately I would like to know how to make LSX recognise the .d2v files as avi, much like tmpenc does.
    Yesterday is history, tomorrow a mystery, today is a gift - which is why it's called the present, so make the most of it.
  5. Thanks for the info, iparout!
    Im trying to figure a way to get DVDx and AVIsynth to
    frameserve to CCE, you may have help out!
    <hr>
    Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
    <hr>
  6. I had the same problem but i just changed the dvd2avi version and of course i turned the proxyoff.reg before i used it. Now it works fine. (DVD2AVI version 1.74)
    Jan 2001
    Vancouver/Portland
    That's odd. I had no problems with DVD2AVI. And all this time I had Frameserving left ON. I have been using VirtualDub to frameserve occassionally over the past week, no problems. Nor any problems with DVD2AVI.
    Hm?
