hi
could anyone tell me the best codec to use and how to get the best results?
i hate having those square pixels on the screen all the time and i know some codecs have better results.
please help.
Codec for what?
Source is what? DVD, Capture, AVI, MPE1, MPEG2?
Destination is what? DVD, DivX, VCD, SVCD, xVCD, xSVCD, CVD, XVCD, KVCD, RM, WMV, MOV, Mini DVD, etc.
If you are having macroblocking (the artifacts on the screen) it can have nothing to do with the codec and everything to do with the bitrate 9you don't think you can put a DVD movie on a CDR and have it look exactly the same?).
We need details to help you.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
source is avi.
destination is dvd.
sorry about lack of info.
but im putting it also on a dvd-r.
ant ideas?
thank's -
AVI:
DV AVI as in a cam?
Downloaded AVI? Size and Length of file(s)?
You have several options. For DVD you want MPEG2 video. You have a number of resolutions to choose from here: https://www.videohelp.com/dvd
Garbage in = Garbage out
You can usually do pretty good going to 352x480. Sometimes 704x480 is better (for those 640x480 AVI's). It depends on the source resolution. There's no hard/fast rule, except that going 'up' (bigger) in resolution doesn't gain you any quality. It will only look as good as the source does.To Be, Or, Not To Be, That, Is The Gazorgan Plan
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Whats an Rpex codec and where can I get it
By Bob2541 in forum Software PlayingReplies: 7Last Post: 21st Feb 2010, 23:20 -
whats best to convert MKV to other HD codec?
By snadge in forum Video ConversionReplies: 4Last Post: 3rd Jul 2009, 22:09 -
whats a good codec pack
By bmzxzx in forum Newbie / General discussionsReplies: 29Last Post: 7th Jun 2009, 18:58 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41
