Am considering buying a used e20 or 50.
both are approximately same price.
doe the e50 have advantages over e20?or e30?
God Bless
The only way to use the flex-rec mode on the E20, is by doing a timer recording. The E30, E50 has a direct flex-rec mode. I had the E20 and got rid of it just because it didn't have the direct flex-rec feature. I only use the flex-rec mode when I backup a movie.
The E-20 had a "black level" bug in that it assumed all incomming video was set to the IRE 0.0 BLACK LEVEL standard. However this is only true of PAL video and Japanese NTSC. However NTSC in the USA/CANADA uses IRE 7.5 BLACK LEVEL standard.
So if you intend to record from USA/CANADIAN NTSC you want the E-50 since it allows you to adjust the input for either 0.0 IRE BLACK or 7.5 IRE BLACK
thank you for the advice.
OK I bid and bought a used e 50.
Wish me luck!
Neext Question
Will an RCA Universal remote work with the e50, no remote comes with it ( sux )God Bless -
RCA remote won't work. It doesn't have all the special features that the E50 requires.
You can buy a new remote from Panasonic for $26.13 @ www.panasonic.com
Originally Posted by Roll Tide
Had this happen once with another peice of A/V equipment. It pays to buy an extra remote for something while you still can just in case you ever need it. The more expensive the equipment the more likely I am to buy a back-up remote "just in case".
What are the differences in these 2 BR Burners?
By golfnut in forum DVD & Blu-ray WritersReplies: 27Last Post: 23rd Apr 2012, 18:14 -
Sony +R Differences
By Madz in forum MediaReplies: 4Last Post: 31st Dec 2011, 02:46 -
Differences between these two files..
By dhr in forum Software PlayingReplies: 4Last Post: 13th Feb 2011, 20:35 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 23:51 -
Player Differences
By Xandal in forum Newbie / General discussionsReplies: 5Last Post: 21st Jan 2008, 14:43
