hi guys
any one help me is there a way to make removing background noise off ac3 file manys thanks for any help
cheers danny
What sort of background noise do you mean?
What do you want to do with the ac3 file afterwards?
Do you want to keep it as an ac3?
As far as I'm aware, you'll have to convert it to PCM WAV to do any real editing on the file - you can then convert back to ac3 with something like BeSweet.
cheers,
mcdruid. -
hi druid
thanks for your reply the background noise is as you more than likey
no if you get svcds on dvd sometimes you get alot off backgrounde
noise alot off buzzing and hissing thanks for any advice you can give
me
thanks danny
background noise in dvd (from .mov)
By nunsepofa in forum ffmpegX general discussionReplies: 6Last Post: 4th Mar 2012, 20:14 -
Dvd with background noise
By Pumkinhead in forum Newbie / General discussionsReplies: 3Last Post: 11th Nov 2010, 09:58 -
Background noise removal - Please help!
By maurof78 in forum AudioReplies: 2Last Post: 3rd Oct 2010, 09:24 -
Background Static Noise..
By Superstar24 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 00:28 -
By pw29010 in forum EditingReplies: 2Last Post: 16th May 2007, 21:27
