I have XP Pro and installed SmartRipper. It did not work so after doing some research I installed the ASPI drivers from Adaptec. It still does not work. I had SmartRipper running just fine last year with a different version of XP Pro. Could that be the issue? Any advice would be appreciated.![]()
In what way does it not work?
Doesn't run/open?
Can't rip?
Throws an error message? -
Really why struggle, not all software can be compatible with every configuration out there. And DVD Decrypter doesn't need any extra ASPI to work with XP Pro.Originally Posted by FT Shark
Operator Error! I did not have all the files selected, now it works great! Thanks for all your time!
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26
