I have a reistered version of the latest version ffmpegX
Can this be done? and where is the too?
major posted 2003 Sep 02 09:37
The registered version of ffmpegX 0.0.8 is able to do it. First check if your player is compatible with "VCD-DVD" by looking at the DVD players compatibility list.
Then put your VCD files in a folder, and use the "S/VCD > DVD" tool of ffmpegX 0.0.8 to automatically reauthor them as one DVD without re-encoding the video.
Regards Barney.
AnonymousGuest
The tool is in the tools tab. The registration page is on http://homepage.mac.com/major4/register.html
the dvd players compatbility list is on this site.
https://www.videohelp.com/dvdplayers.php
AnonymousGuest
Ok thanks guys I now have 8 Converted DVD files containing AUDIO_TS and VIDEO_TS in separate folders These total 3.8GB.
How do I set up menus etc to burn to one DVD-R disk?
Just burning them as they are in their 8 folders gives me an unreadble disk in my TV DVD player.
Each folder play perfectly in VLC and Computer DVD Player.
Thanks a million for your help so far
Barney
Keep the .m2v and .mp2 files for each segment and use Sizzle to combine them and add the menu.
AnonymousGuestWhich exactly are the VCD files? I have to SVCDs here with three folders inside them. Is it enough to copy the MPEG2-files to one folder, or do I need more files?Originally Posted by major
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Help with VCD to DVD
By bwheeler in forum Newbie / General discussionsReplies: 9Last Post: 28th Jun 2007, 02:25 -
Dvd to Vcd
By tryst1 in forum Video ConversionReplies: 2Last Post: 5th Jun 2007, 01:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
