Hi all !
is there any way to order to reisze a mpeg file without encode again ?
Luuca
Not really, but you can trick the decoder into thinking the mpeg(2) has a different resolution than it really has. (This is sometimes used to make SVCD video DVD compliant without reencoding.)
Here's a tool for this.
/Mats
PS! I see "resize" is somewhat ambigous: do you mean "change the file size" or "change the resolution" ? DS -
Hi all again !
I have a mpeg1 file and I would like change the resolution. It is 352x240 and I need resize to 352x192 and add borders. This way I will have a 352x240 file. I maked a very good VCD with the original but it was stretch in high. So I resize and add borders in Virtualdub, re-encod with TMPEGenc and maked a VCD with VCDeasy, but the result was bad because the re-encode... -
No can do without reencode, unfortunately. The mpeg was obviously made for stretching out on a 16:9 TV. Live with it, or forget it.
/Mats
How to resize and convert MPEG-2 file so I can work with them in PrPro CS4?
By tomchook in forum Newbie / General discussionsReplies: 7Last Post: 13th Apr 2012, 11:02 -
Encode YouTube video to MPEG-2
By RL in forum ffmpegX general discussionReplies: 4Last Post: 31st Jan 2011, 23:31 -
Crop/resize mpeg-2 to remove pop-up ad
By CaZeek in forum EditingReplies: 9Last Post: 8th Sep 2008, 22:43 -
Can't encode VOB to MPEG-2
By radellaf in forum ffmpegX general discussionReplies: 3Last Post: 11th Jun 2008, 19:08 -
Resize Suggestion for AVI-DVD Encode
By Soopafresh in forum Video ConversionReplies: 10Last Post: 26th Jun 2007, 11:01
