  1. How do I get the MPEG file from VOB?? DVD2AVI generates a d2v file..i'd like to know how to get the MPEG file from the VOB's
  2. Since a VOB is essentially an MPEG file, any program that demuxes the VOB into elementary streams should work.
  3. Banned
    Oct 2003
    Americas
    Not exactly. This is a container format like zip, rar etc. that DVD understands and can access MPEG stream inside.
    There are tools that will allow you open and extract video or audio streams from it like VOBedit or VOBrator. Vegas can do it as well.
  4. Member wulf109's Avatar
    Jul 2002
    TMPEG is also excellent for demuxing and remuxing vob files. Go to Mpeg Tools in the file menu and open.
  5. Originally Posted by wulf109
    never failed me once
    You may run into problems doing it like this. I suggest VOBEdit too.
  7. It also depends what sort of MPEG you want - what's your overall aim?
    MPEG is used in VCD (MPEG-1), SVCD & DVD (MPEG-2) and if you want to be pedantic, DivX etc.. is also MPEG (MPEG-4).
    You'll have to be a bit more specific if you want specific help.
    Also, there are dozens of guides about this in the guides section over on the left.
    cheers,
    mcdruid.
