  1. Banned
    Oct 2003
    Pearl Harbor USA
    I already tried with VCDGear &IsoBuster. VCDGear just hung, and IsoBuster just kept on trying to read the bad sector/track over &over, even after I asked it to ignore the read error.
    Any suggestion is appreciated, thanks in advance.
  2. Member bithead9's Avatar
    OK here are two things you can try...
    1) get some spray on furniture polish and gently polish the
    VCD from the center out to the edges all around the disk.
    Then try to play/copy the thing.
    If that does not work try this:
    2) Do the same thing with tooth polish but very gently as it it
    abrasive. It will eventually destroy the VCD surface. yuo really have to be careful.
    Good luck!
  3. Banned
    Oct 2003
    Pearl Harbor USA
    bithead9, thanks. I already tried that too, no luck.
    I really don't mind if I lose some of the data or video frames here as long as I can extract most of the mpeg file. DVDDecrypter is pretty good at ignoring read error if it has to, so I even used DVDDecrypter for this, but unfortunately, DVDDecrypter can only do DVD, not VCD. Does anyone know a VCD tool similar to DVDDEcrypter but handles VCD?
  4. If all else fails you could use CamStudio to capture what you see on your software player,that is if it will play.
  5. Banned
    Oct 2003
    Pearl Harbor USA
    MOVIEGEEK, thanks for the suggestion, my SW VCD and DVD/VCD standalone players hang at the scratched spot, which is why I want to recover/backup as much as possible.
