Hi everyone...
I'm a newbie (I feel like I'm learning 1+1 = 2) who's been trying to make SVCD's for a few days with DVD2SVCD...Some got to the end of the process, some didn't. This package uses many programs like MADPlay (which fails half the time), bbMPEG (don't ask me what it does) etc...
My question is : Can TMPGEnc do all the work itself ??? like decoding audio, re-encoding, multiplexing etc...maybe with a few external programs like "tooLame" (read that here somewhere) and produce a good quality SVCD ??? (I said SVCD 'cause I do want good quality, otherwise I would just stick to my VCR)
Thanks for helping !!
For what you are looking for TMPGENc should do everything. Most would admit that it is probably not the best for encoding the audio, but it's top notch for everything else that you listed. A lot of people will just encode the audio separate in some other app like tooLame or BeSweet, then mux them together in their authoring app. TMPGENc does not like AC-3 files. It does fine with MP2 audio though.
Toolame can be configured to work with TMPGEnc as an external encoder, no need to create two files and mux. I find TMPGEnc's audio to be not too bad though.Originally Posted by andkiich
TMPGEnc does not like VBR encoded MP3 either, I use Goldwave to extract the audio from all avi's and then use the resulting wav as the audio source for TMPGEnc."Art is making something out of nothing and selling it." - Frank Zappa -
Very few software apps do. I would never recommend using VBR for audio in ANY circumstances - either music or video.Originally Posted by vtoskov
Are you planning on ever getting a DVD burner and copying these SVCDs to DVD? If so, I would recommend that you not make SVCD's but rather CVD's. CVD's use files that are compatible with DVD standard, but SVCD uses a different resolution, and the sound is not DVD compatible. True good players today will play SVCD, but the format is dead, and I can't imagine that support for it will last much longer.
To convert SVCD's to DVD you'd need to re-encode the video, which will take a hit in quality, and resample the audio to 48kHz. If produced correctly (both video and DVD compatible 48kHz DVD sound) a CVD will give quality every bit as good as SVCD and is easily converted to DVD without any need to re-encode, thus preserving the quality that is important to you.
For me, I use TMPGenc for nearly everything. It produces great video, but I do use Toolame to create the audio. The difference isn't overly dramatic, but it's worth a few extra minutes.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
