  1. I like user the Tmpgenc wizards as I do alot of batch encoding and find it easier to use then using templates....
    Is there a way to add one of my templates to the Project Wizard in Tmpgenc ?
    Apr 2002
    The State of Frustration
    Once you have changed the settings, click on the Save button on the bottom of the main screen. Give your template a name, and it should appear in the wizard with the rest of the templates.
    Hello.
  3. Thanks...I know how to save the template...BUT how do I add it to the project wizard as I can only load it by doing using the LOAD buttom at the bottom of the screen...It does not display in the Project Wizard....
    Apr 2002
    What version are you using, and did you mke sure the new template is in the template directory?
    Hello.
  5. 2.58 Plus
