i hope someone can help me out![]()
i've come across some .gi dvd images. i can't burn them because prassi/recordnow do not recognise my dvd-r/w drive (it's an lg gsa-4040b flashed with the newest firmware).
there are multiple files per image, and they look like this:
image (11).gi
image (12).gi
image.gi
how can i get them to a format (like .iso) so i can burn them? i have nero 6 and alcohol 120% ready to go!
ToXiC
you can use the new isobuster 1.5 to extact all the files and then burn the files.
or
rename all the .gi files like so input1.gi, input2.gi, input3.gi
and then use this dos command.
"copy /b input1.gi + input2.gi + input3.gi output.iso"
(not "quotation" marks)
make sure you dont combine the small .gi file (its kind of like a cue file) -
ahh, sweet, i'm going to give the copy thing a try... makes sense.
thanks!@$ToXiC -
Also do you have the latest updates and the px engine for Recordnow maxOriginally Posted by ToXiC
yes, i did download the latest engine for recordnow max. it's dated november 2002, so i'm thinking it's not supported anymore...
ToXiC -
Here is a program that will convert them also
http://www.ezbsystems.com/enindex.html -
thats pretty odd that your dvd burner isnt supported by RNM.. you're using version 4.5, right?
you might want to give recordnow max dx (i think its ver 4.6). the only place i've seen it is bundled with a sony dru500a.. -
Why don't you either:
a) burn them with DVD Decryptor, it's free and one of the best
b) jump into DOS and type this command:
copy /b file1.gi+file2.gi+file3.gi fulliso.iso
Don't include the tiny .gi file, and presto you have a nice ISO file that can be burned with almost anything, and can be mounted with Daemon Tools..
Convert webcam images to time-lapse vid, thenupload to YouTube...NEED HELP!
By EricFW in forum Newbie / General discussionsReplies: 1Last Post: 12th Apr 2012, 06:34 -
images
By AlanHK in forum TestReplies: 4Last Post: 4th Mar 2010, 14:12 -
Images and popups
By stiltman in forum FeedbackReplies: 6Last Post: 27th Jan 2010, 17:06 -
HD images
By toneystone in forum Newbie / General discussionsReplies: 3Last Post: 21st Oct 2008, 12:50 -
panning across still images
By ath1517 in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2007, 05:39
