  1. Im trying to backup my copy of terminator2 region 4 but it rips the audio in french not english i have done about 15 rips allready this is the first time this has happend plz help a guy out
  2. USe smart ripper or your favorite software to rip the vobs, then use dvd2avi, under audio, select a different channel, try doing just a very small portion (a minute or two) and see if that is the right channel, if not, select another, you can use window media player to listen to the wav file dvd2avi creates
  3. When you say it's in french do you mean the VOB files, MPEG, DivX, etc? The VOB files normally hold ALL the audio tracks. But you can extract whatever language you want from them.
    I don't know what software you are using, but under DVD2AVI select the desired audio track (if you ripped w/ smartripper it'll create a info.txt file that lists them).
    Flask, DVD2SVCD, DVDx, etc. just allow you to choose the track you want.
  4. thank u very much and sorry i use smart ripper dvd2avi and tmpgenc and after reading about this site i no drive a 1.4gig athlon mmmmmmm fast
