I've been using the Win-Go TV card, and its great, but now I'd like to imput from a SVHS recorder, and need a card that allows that.
I use VirtualDub, Huffy lossless compression, and the btwincap drivers, and capture at 640X480. Also my computer has a Pentium III 500mHz chip and I have 128MB of RAM.
I would really appreciate advice on a good, fairly inexpensive card that isn't too difficult to set up.
Thanks,
George
The Leadtek Winfast TV2000XP should do the trick, and is fairly inexpensive (about $55 USD the last time I looked at Newegg.com). I believe it uses the same capture chip as your existing board so your btwincap drivers should still work.
Any card can grab from the S-VHS players composites, many from coax. Some from s-video.
S-VHS is a tape format. s-video is a connector wire.Want my help? Ask here! (not via PM!)
Any card that has s-video input can do that obviously (if we're talking SVHS capture quality with 420 lines). S-video has separate luminance and chrominance connectors and IT WILL give better picture quality when viewed on a GOOD screen. But for day-to-day capture purposes there are "s-video to rca" connectors if quality is not that critical. Many viewers will not notice the difference though.... from my experience.
In general, try to use s-video whenever possible. If not? It's not a tragedy. Use RCA video jack.
Looking for SVHS PAL capture device with timecode support
By nf42day in forum Capturing and VCRReplies: 2Last Post: 14th Jun 2011, 15:43 -
Problems with flashing colours on VHS/SVHS capture
By nick1977 in forum Capturing and VCRReplies: 20Last Post: 5th Mar 2010, 07:09 -
New Capture VCR for old VHS/SVHS tapes
By mark23 in forum Capturing and VCRReplies: 3Last Post: 22nd Feb 2008, 10:44 -
Can't Capture Useing RCA imput
By Ensign in forum Capturing and VCRReplies: 4Last Post: 31st Oct 2007, 00:36 -
SVHS Capture / Premiere Pro 2
By tokyomaskproductions in forum Capturing and VCRReplies: 4Last Post: 16th May 2007, 14:48
