hello ı'am turkish ı am wrong englısh sorry
pls help me
Starting SVCD2DVD DEMO: v1.5.1416.29638
Begin time: 21:24:56
Analysing File: D:\filimler1\3xx_1\AVSEQ01.mpg
-->Processing 1 mpeg files.
############### New MPEG File ###############
Type: VCD
Horizontal Res: 352
Standard: PAL
Audio SampleRate: 44100
******** Preparing asset
******** Demultipexing original mpg file
******** Resampling audio from 44.1 KHz to 48 KHz
******** Multipexing elementry streams
Analysing File: D:\filimler1\3xx_1\AVSEQ01_DVD.mpg
******** Creating DVD Folders...
Creating VTS #1
============ Complete ============
============ Duration: 00:01:09.3897776
video_ts folder is VTS_01_0.VOB file 16 kb and zero video pls help
and log file
log
Unhandled Exception: System.NullReferenceException: Object reference not set to an instance of an object.
at DevComponents.DotNetBar.Bar.RecalcLayout()
at DevComponents.DotNetBar.Bar.59()
at DevComponents.DotNetBar.Bars.OnClear()
at DevComponents.DotNetBar.DotNetBarManager.Dispose(B oolean disposing)
at System.ComponentModel.Component.Finalize()
++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
++ WARN: packet length beyond buffer (pos = 18 + size = 2306 > buflen = 398) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #453 (stream byte offset 1048178) -- remaining 398 bytes of stream will be ignored
++ WARN: autopadding requires to insert additional 4594 zero bytes into MPEG stream (due to 2 unaligned packets of 453 total)
Type: VCD
Horizontal Res: 352
Standard: PAL
Truncating Asset.
Truncating Asset - done.
Now processing AVSEQ01_D.mpg 1/2 ...
Now processing C:\Program Files\Badgersoft\SVCD2DVD DEMO #2\PALVCD.mpg 2/2 ...
bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
speed increases by, Apachez and Christian Vogelgsang
Saving stream 0xE0 into file D:\filimler1\3xx_1\AVSEQ01_DVD.mpv...
File D:\filimler1\3xx_1\AVSEQ01.mpg is an MPEG-1 Program Stream
Invalid bits in MPEG-1 file D:\filimler1\3xx_1\AVSEQ01.mpg.
Saving stream 0xC0 into file D:\filimler1\3xx_1\AVSEQ01-0.mp2...
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
**ERROR: [mplex] Unable to read from D:\filimler1\3xx_1\AVSEQ01_DVD.mpv.
**ERROR: could not stat() file `D:\filimler1\3xx_1\AVSEQ01_DVD.mpg': No such file or directory
Error getting mpeg details. (probably due to AC-3 audio)
System.IO.FileNotFoundException: Could not find file "D:\filimler1\3xx_1\AVSEQ01_info.xml".
File name: "D:\filimler1\3xx_1\AVSEQ01_info.xml"
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials)
at System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn)
at System.Xml.XmlTextReader.CreateScanner()
at System.Xml.XmlTextReader.Init()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlValidatingReader.ReadWithCollectText Token()
at System.Xml.XmlValidatingReader.Read()
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at j.n(g A_0)
at j.n(g A_0)
Creating VTS #1
SVCD2DVD: DVDfolders
Generating DVD folders please wait....
-->: DVDFolders creating VTS
-->: VTS 01
STAT: Processing C:\Program Files\Badgersoft\SVCD2DVD DEMO #2\dummymenuPAL.mpg...
STAT: Processing D:\filimler1\3xx_1\AVSEQ01_DVD.mpg...
***: Error opening D:\filimler1\3xx_1\AVSEQ01_DVD.mpg: No such file or directory
-->: DVDFolders creating table of contents
***: No .IFO files to process in C:\Documents and Settings\EA\Desktop\Yeni Klasör (2)\VIDEO_TS
and sorry wrong english sorry
The demux is failing:
Invalid bits in MPEG-1 file D:\filimler1\3xx_1\AVSEQ01.mpg.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Pls help with my TV USB video problem - does not support dts and subtitle
By emfung in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2011, 05:52 -
Corrupt video/SD card. Need help pls.
By Ronin Silfar in forum Newbie / General discussionsReplies: 9Last Post: 14th Mar 2010, 17:46 -
How to 'un-squeeze' video to normal size - cropping, etc...pls help!
By rairjordan in forum EditingReplies: 4Last Post: 22nd Dec 2008, 21:14 -
Anyone know how play IVM video files pls?
By amdk62 in forum Newbie / General discussionsReplies: 15Last Post: 27th Sep 2008, 08:52 -
Pls suggest compact Video format for episodic storage on DVD-R with menu
By Firewire60 in forum Video ConversionReplies: 2Last Post: 10th Jun 2007, 03:37
