Hi,
I plan to get Digital Matrix branded DVD+r 4x from Meritline.com (100 for $89), but don't know how well is this brand perform on the Lite-on 401S. Please give me some advices before purchase these. Or any cheap DVD+R 4x branded that works on this drive. Thanks.
Thanks for all the help. -
the media code for the matrix media as of about 2 months ago is
MEDIA ID001
Look up that media code and see what you get.. not sure on your burner, but I got duped with my optorite... can't use it to burn at 4X ... there is not 4X write descriptor so any dvd burner that reads that and sets burn speed will only use it as 2.4X .Visit the meritline forum and look for a compatibility listing for that media... if you buy it and it doesn't work, they won't do a whole lot for you... I spent over 3 weeks to get a whole 5$ back on my order... good luck....Warning!!!!
Meritline is a fraud.......
Lite-On Burner Will Not Read DVD+R Media
By kca741979 in forum MediaReplies: 11Last Post: 28th Feb 2010, 01:47 -
Matrix DL DVD+R, Any Good?
By Des in forum MediaReplies: 12Last Post: 23rd Feb 2010, 14:21 -
Why does my Lite-On DVD burners fail on 8x DL discs?
By Onceler2 in forum MediaReplies: 26Last Post: 5th Jul 2009, 01:11 -
Lite-On A110 DVD recorder, problem with RW discs
By Jack_Dante in forum DVD & Blu-ray WritersReplies: 1Last Post: 7th Apr 2009, 09:50 -
Anyone have Lite DVD Recorder On DD-A100GX ? ? ? ? ?
By HolyGeez in forum DVD & Blu-ray RecordersReplies: 8Last Post: 30th May 2007, 08:58
