Hello everyone, I'm not sure if this is supposed to be in this area or not, the rules said dvd ripping and dvd conversion. The format is actually vcd but will be burned on a dvd. Anyhow my question is this. I have all my files in vcd mpeg1 and the audio is at 48khz. Now do I have to use that dvd authoring cause its buggy for me. Or can I go directly to nero6. If I can go directly to nero6, do I choose the cd/vcd area or the dvd/video area. What do I choose to burn these files on a dvd disc. Thanks.
Guest
Demux(.m1v & .mp2) the MPEG and use IFOEDIT ->DVD Author.Then in Nero use DVD-Video.
www.dvdrhelp.com/forum/userguides/120013.php -
Guest
Well I went ahead and did it like lordsmurf suggested first. http://www.lordsmurf.com/convert/vcdtodvd/vcdtodvd.htm I just added my files in there and it did it's thing in a folder now what is left a VOLUME 1 folder, and once you click it you see a AUDIO_TS which has nothing in it, and a VIDEO_TS which has files in it. When I open nero dvd video do I copy over the volume1, or click on it and copy both audio_ts and video_ts or just video_ts folder. Or do I just open the video_ts folder which has the files and copy the files over to the nero's folder that says video_ts. I tried that but it said one of the files named default.pls didn't go in that folder. I'm kinda lost. Heres a screen shot of the files in the video_ts folder on my hd. Well I couldnt get a screen shot to work. the files are as follows:
default.pls
video_ts.bup
video_ts.ifo
video_ts.vob
vts_01_0.bup
vts_01_0.ifo
vts_01_0.vob
vts_01_1.vob
vts_01_2.vob
vts_01_3.vob
vts_01_4.vob
vts_01_5.vob -
Guest
well then that would be the folder audio_ts and video_ts, that is the folders after u open volume1. And the only folder that has files is video_ts. So you are saying copy audio_ts and video_ts folders from harddrive into the neros complication folder saying video_ts under dvd-video?
Guest
Yah I figured it out, thanks u guys. It burned perfectly and read perfectly in my stand alone dvd player. Peace
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 17th Jun 2010, 00:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
