I'm using WinDVD Recorder and am having difficulties when capturing video at the 720x480 setting. I seem to be able to make nice captures when I choose the 352x240 setting though. I've uploaded two stills of the two captures. Notice the whacked-out, B&W/purple/green color of the second one.
http://heylad.hypermart.net/capture1.jpg
http://heylad.hypermart.net/capture2.jpg
Any idea why it's doing this? I had the same problem with WinDVD Creator2.
I don't know if this is a factor or not, but if you look at the properties of the jpegs, they show that their sizes are actually only 320x240 and 640x480 respectively. Could this be part of the problem? Any ideas on what I should do? The video card I have is: 128MB DDR ATI Radeon 9800.
Results 1 to 9 of 9
If it was easy, I would be doing it.
How fast is your system, (CPU and Hard Drives)?
I am working out capture issues with my system. I have seen similar problems using VirtualDub and various codecs. So I will bump this post and hope I see your solution. -
Thank you for the reply. If you click on the "computer details" option right above my message, you'll see that information. I sincerely appreciate any help you can provide.
Btw, what do you mean by "bump this post"? -
If you have an ATI AIW card, use ATI MMC, not another capture program.
Originally Posted by heylad
Keeping it on top/active instead of it getting lost in the shuffle, so to speak.
Whenever someone responds to your post, it goes to the top of forum listing...hence makes it easier to see/find -
Originally Posted by ImaWeTodd
The good video -
"File : 1.71 MB (1.98 MB), duration: 0:00:05, type: MPG, 1 audio stream(s), quality: 80 %
Video : 1.85 MB, 3072 Kbps, 29.970 fps, 352*240 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 136 KB, 224 Kbps, 44100 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported"
The bad video-
"File : 12.19 MB (0.0 B), duration: 0:00:00, type: MPG, 0 audio stream(s), quality: 0 %
Video : 12.19 MB, 0 Kbps, 0.0 fps, 0*0 (), MPG2 = MPEG 2 (SVCD/DVD), Not checked"
Pretty strange, huh? -
Originally Posted by Rookie64
16:9 1080i to 4:3 720x480
By fishywishy in forum Video ConversionReplies: 4Last Post: 4th Apr 2010, 23:51 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 05:50 -
DV to 704x480 or 720x480?
By Almost Human in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 11th Dec 2007, 19:37 -
Anyway to capture 720x480 using the Gamebridge and still play?
By Mysteriouskk in forum Capturing and VCRReplies: 0Last Post: 19th May 2007, 13:07
