DVDPatcher is great for MPEG-2, but was clearly not designed to patch the headers in MPEG-1.
I don't even think that MPEG-1 *has* an aspect ratio tag, since every time I've loaded good MPEG-1 files into DVDPatcher, the aspect ratio shows up as a few garbled characters...
Use SVCD2DVD to patch MPEG-1 files (from a VCD?).
Phillip
www.allaboutduncan.com
"Oh, they have the Internet on computers now."
Well, VCD resolution (352x240 and 252x288) is already a DVD compliant resolution, so I generally have no need to patch the resolution of MPEG-1. I have, on on odd occasions, wanted to patch the framerate though...and this is something that SVCD2DVD does not do.
Imagine, for instance, that you downloaded a screwed up VCD that is 352x240 and 25 fps. This VCD could be fixed by patching the framerate to 23.976 and then stretching the audio (using GoldWave) by the ratio 25/23.976. In this way, you create compliant NTSC VCD that can be authored to DVD *without* re-encoding the video.
Repairing mp4 headers manually.
By Wojo J in forum Newbie / General discussionsReplies: 6Last Post: 31st Dec 2011, 08:01 -
Problem with missing headers
By twentworth in forum DVD RippingReplies: 8Last Post: 22nd Jan 2011, 01:19 -
How to patch 352x480 MPEG-2 to 720x480
By moxiecat in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 13:43 -
Possible to search headers of Usenet newsgroup?
By sdsumike619 in forum ComputerReplies: 15Last Post: 14th Sep 2009, 22:42 -
Patch resolution in .vob files
By geohei in forum Authoring (DVD)Replies: 3Last Post: 18th Jun 2008, 01:12
