ok i have win98 and win2000 server installed in the same pc.ok in win98 everything works fine but in win2000 theres a problem with my dvd rom and my cdrw they r not working when i go to device manager it says "Your registry might be corrupted code 19" does anyone know how to fix this problem? i virus scan no virus found
thankx in advance
http://www.jsiinc.com/SUBH/tip3700/rh3766.htm
may or may not help ya. it's just the first thing that popped up from a google search for "registry error code 19" -
Or, you could try the Microsoft Knowledge Base...
A search for "registry error code 19" under the Windows 2000 section ...
http://support.microsoft.com/support/kb/articles/Q295/7/73.ASP?LN=EN-US&SD=gn&FR=0&qry...CH&SPR=WIN2000
Is it possible to fix that ???
By cd090580 in forum Newbie / General discussionsReplies: 8Last Post: 8th Sep 2009, 15:46 -
how to fix h264?
By hanugro in forum Newbie / General discussionsReplies: 9Last Post: 13th Mar 2009, 22:02 -
how do I fix this audio
By Remyisme in forum AudioReplies: 7Last Post: 25th Oct 2008, 14:00 -
fix subtitle
By sharmine in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2008, 21:19 -
Can I fix a VCD?
By Haopengyou in forum Authoring (VCD/SVCD)Replies: 6Last Post: 1st Feb 2008, 00:26
