I'm trying out TMPGEnc DVD Author since DMF2 no longer allows the workaround for AC-3 sound.
I've got my little project here ready to burn, and the trial run (burning to a DVD-RW) went fine and dandy. No problems whatsoever.
But then when I tried the exact same project on a DVD-R, it burned for about a minute and displayed this cryptic error message:
"Writing error. Cmd:42, Scene:5, ASC:33, ASCQ:2"
When I clicked the OK button, ANOTHER even more cryptic error message appeared:
"BUR"
When I clicked the OK button, the disc ejected a nice little coaster for me.
I tried another disc, got another coaster.
Any ideas what's going on here? Thanks...
Results 1 to 9 of 9
Had same prob myself dvd-rw was ok dvd-r burnt ok but wont play
So now I just stick to nero for burning TDA's output and no more probs -
You read my mind...Originally Posted by Roderz
I was just about to post that I exited TDA, and burned the exact same VIDEO_TS folder to a DVD-R with Nero, and everything went hunky dory! Guess TDA's "DVD Writing Tool" has a bug that needs to be fixed in the next release.
Thanks! -
Which version of DVD Author are you using?
I'm using 1.5.13.44 with no problems. I was going to upgrade to 1.5.15.49, but if this is what is going to happen, maybe I'll wait... -
I'm using 1.5.13.44 as well
But my dvd writer is not on their compatability list
so I cant complain.
As long as nero keep working
BTW I did post on this here https://www.videohelp.com/forum/viewtopic.php?p=641648&highlight=#641648 nearly 2 months ago.
Basicly if I burn dvd-r with TDA disc will only play on 1 of my 3 players
TMPGEnc DVD Author BBS (not easy to find from their web page!)-- http://www.pegasys-inc.co.jp/bbscgi/ebbs/board.cgi?board=tda -
Never a problem here! Never a coaster, and every disk plays in every player I have tried them in after burning with Tmpgenc Dvd Authors built in burner! Unlike the disks I Burned with Nero! Half them won't play in some players, All play in mine, and I found one player that played none of them. So for me Nero is a pot luck deal, may work may not!
Maybe you Guys having problems have a newer version than I do? Try going back to the previous version and see if it works for you. Not sure what version I have off hand, not at that system.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
TMPGEnc DVD Author 3
By WHISPERS1944 in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2008, 04:56 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
