I recently purchased a Lite-On 411s and a Haupauge PVR250 with the intention of transferring my home VHS movies to DVD. After many, many hours of compatibility problems with the Haupauge, I finally managed to get some film captured onto my H/D.
Ulead DVD movie factory which came free with the card does not allow editing which is vital to me.
Sonic MyDVD which came free with the burner produces mpeg2 files that are not recognized by my stand alone player (Reoc A5).
I have the same problem with files produced with Pinnacle studio8, and it is so slow at rendering it`s untrue, so I D/L a free trial of NeoDVD5 due to recommendations on your forum. I now have found out via their helpdesk, that my burner is not supported by NeoDVD because it will not recognize ANY blank DVD that is inserted.
I can make a straight copy of any DVD or SVCD with the afore mentioned blanks using Xcopy and it will play fine on my Reoc. My Reoc will not play a DVDRW`s under any circumstance and I`m soooooo sick of producing coasters at £1 a time.
Any ideas plz
have you tried a program called Showshifter pretty good with your capture card
Once you have edited the footage, then open that in movie factory and let it create the file structures for you. -
FAO Richard
No, I`m not just burning the Mpeg files I`m going through all the req`d processes req`d by each different bit of software to produce a DVD that I can play on my standalone but nothing I produce will play on my Reoc. Other DVD`s & SVCD`s from friends will play fine, I`m really pulling out the little hair I have left. -
It might be worth starting from scratch and not trying to run before you can walk. Capture an hour or so of video using DVD movie factory, don't try editing or adding any menus or anything, just go straight to the encode and burn stage and produce a DVDR. See if that plays in your Reoc.
This will at least confirm your media and burner are OK. -
FAO Richard
Thx m8 It works
I can achieve my goal if I...
Capture through WinTV
Edit/render through Pinnacle Studio8
Burn through DVD Movie Factory
A very long, drawn out and time consumig process and 1st results are grainy but I`ve got something to work on untill NEODVD have got supportd drivers for my burner.
Thx 2 all for help
Avi burning problems
By blitzen in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2011, 12:09 -
Dl burning problems
By calanda in forum DVD RippingReplies: 13Last Post: 13th Apr 2010, 23:25 -
TYG02 burning problems.
By videobread in forum MediaReplies: 2Last Post: 11th Oct 2009, 12:51 -
DVD burning problems
By ssaamm in forum DVD & Blu-ray WritersReplies: 10Last Post: 22nd Sep 2007, 00:11 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 15:36
