Hi!How can i convert a .vob file to .mpeg2 file?
You're asking a lot of questions this morning!!
I'd suggest reading as much as you can from the guides and articles - the questions you are asking are all covered there:
cheers,
mcdruid.
[edit]
- just clicked on that search in the guides, and it came up with zero results!!
What are you trying to achieve?
People will be able to help more if you give an overview of what you're trying to do.
[/edit] -
Vasilis try this
https://www.videohelp.com/mpeg2tovcd.htm
it is a vcd guide but you can set tmpgenc to whatever type of mpeg output you desire.
Guido
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
VOB into one(!) mpeg2 file
By mitchellgoosen in forum ffmpegX general discussionReplies: 2Last Post: 13th May 2009, 09:19 -
Best way to convert NTSC .VOB --> PAL .VOB
By macuser1960 in forum ffmpegX general discussionReplies: 1Last Post: 9th Mar 2008, 16:43 -
Convert NTSC VOB --> PAL VOB
By djdust in forum Newbie / General discussionsReplies: 2Last Post: 5th Dec 2007, 11:29
