Hi guys, I'm a newbie and have been lurking for a few weeks trying to figure out this problem from alot of other folks posts, but I can't seem to get it figured out. I can encode from a .vob to a vcd, but get the following error message when I try to encode to SVCD.
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
Wed Nov 19 22:35:24 PST 2003
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
usage: movtoy4m -w width -h height -F a:b -a a:b [-s] [-f] [-o ppm/y4m] movie.mov
example: movtoy4m -w 352 -h 288 -F 25:1 -a 4:3 pal_normal.mov
example: movtoy4m -w 352 -h 240 -F 30000:1001 -a 16:9 ntsc_wide.mov
**ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
I have Quicktime v6.4, and I installed the mpeg2 encoder plug-in, I have the QT box checked in the options tab. I use the SVCD Quick pre-set.
I trashed my 1st version of ffmpegX and reinstalled according to the directions, still no luck. I don't know what else to do. My machine is a Wallstreet G3 466Mhz with OSX 10.2.8, 512mb RAM. ( I know she's old, but she's built like a tank and is still performing beautifully 5 years later!)
Help!
jaytbird2Guest
jaytbird2Guest
Thanks, Major. That was the correct answer. I installed the decoder and Voila! it works. Just a note to all you "older" G3 users....it works. It just takes a while....I'd say about 20 hrs for a regular DVD to SVCD.
Thanks again Major. Great program.
JW
Encoding .Avi to Svcd?
By mrjust in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2011, 14:40 -
Encoding VIDEO_TS to mpeg-2 SVCD
By phamtom in forum ffmpegX general discussionReplies: 6Last Post: 27th Apr 2008, 16:05 -
encoding problem
By ifotel in forum ffmpegX general discussionReplies: 0Last Post: 19th Nov 2007, 11:46 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 12:41 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56
