I want to make nonstop CD using 15 songs of 2 minute each. Through Cooledit I made it by mixing 15 tracks using fade in and out operations. Fine, but it has made a single track of 15 songs. Problem is while making audio cd I want to break them in to 15 different tracks maintaining nonstop sequence so that it can be switched by using next button. How can I do this Kindly help.
Well since you are burning it to a cd.....if you use nero, what you can do is...........nero has an option that lets you change the amount of time between the trackes. So if you put all those in and put the silence time between each track to 0 seconds then it should do what you are looking for. Just a thought. Never tried it myself but I don't see why it wouldnt work. I believe the default silence between tracks for Nero is 2 seconds.
Good Luck
HatzLoves the funeral of hearts..... -
i ran in to this problem a few years back when i was trying to make a cd from a live concert which i had the mp3's of.
even if you do set the gap between the tracks in nero to 0 you still get a slight pause between tracks.
the way i found to make a "nonstop" cd was to convert all the mp3's to wav and merge them through cool edit.
then i took the wav in to nero, dragged it to the current compilation (left side), right clicked on the wav & selected properties, then click the "indexes, split, limit" tab and scanned through the wav until i found where i wanted to split each track, after that i set the gaps to 0 seconds..
nice & smooth all the way through.. -
Previously, the only good way of doing this was with CDRWin and editing the cuesheet but the above method with Nero is probably the best way of doing it now.Originally Posted by jeex
Regards.Michael Tam
w: Morsels of Evidence -
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
AVStoDvd Help, urgent
By DaneClark in forum Authoring (DVD)Replies: 1Last Post: 21st Oct 2010, 21:22 -
messenger urgent help!
By alintatoc in forum ComputerReplies: 2Last Post: 1st Jun 2009, 10:39 -
Urgent computer help
By Seasonal in forum ComputerReplies: 24Last Post: 23rd Jul 2008, 03:49 -
Kindly advise on the best mpeg editing software. Thanks.
By seymoria in forum EditingReplies: 18Last Post: 7th Dec 2007, 09:25 -
Two sets of Subtitles In Video Kindly Help?
By zephyr360 in forum SubtitleReplies: 1Last Post: 14th Jul 2007, 16:45
