  1. I want to make nonstop CD using 15 songs of 2 minute each. Through Cooledit I made it by mixing 15 tracks using fade in and out operations. Fine, but it has made a single track of 15 songs. Problem is while making audio cd I want to break them in to 15 different tracks maintaining nonstop sequence so that it can be switched by using next button. How can I do this Kindly help.
  2. I see you are using Cool Edit. That's what I used to make my compilations. Here's how to do it in Cool Edit:
    - Take your large file, and select the first song. Highlight it until the end of the track, where you'd be happy for the next track to start.
    - Right click your highlighted part and select "Copy selection to new". Save this new file - this is one track.
    - Go back to the original big file and press delete. Don't rehighlight it - you'll not get perfect timing!
    - Repeat as required.
    - In case of overdose, massage clicking finger.
    On the other hand, I think that some CD burners have a function built in that allows you to put in track marks. Also, beware that you tell the CD burner not to put any gaps in between tracks!
    Good luck!
    CobraDMX
    (Edited once due to my fat finger typos)
