Sorry if this has been covered, but what is the max capacity you can put on a SVCD DVD? It's not 4.4 which I thought was fine...
And is there a way that SVCD2DVD could tell me it won't fit BEFORE I tell it to create VTS's?
Thanks.
Love the program![]()
AnonymousGuest
Well it depends on your burning software and media. (you can put more on - media than +, i think i'm right in saying).
There is no point in SVCD2DVD stating the projected size of the DVD before it was created as it would be a total guess. Whilst the process is the same, dif mpeg structures result differently to the process.
The best thing is to aim for say 4.3GB (sum of your sources), load it up in your burning prog - if you need to reduce the size a bit, use dvd shrink, if not note how much space you got & add that to your initial "limit"SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
only a little bit. a search on one of the other forums should get you the exact details.
Burning to Full Capacity of a DVD
By Agent 5 in forum MediaReplies: 6Last Post: 16th Apr 2012, 09:49 -
Simple question on DVD+R DL discs/Capacity
By alegator in forum MediaReplies: 12Last Post: 19th May 2011, 04:52 -
New storage capacity
By GideonK in forum Latest Video NewsReplies: 30Last Post: 11th May 2009, 13:48 -
Exact maximum capacity of DVD+R
By geohei in forum Authoring (DVD)Replies: 18Last Post: 21st Mar 2009, 09:23 -
Roxio 8 misunderestimates DVD capacity? making lotsa coasters...
By ahhaa in forum ComputerReplies: 8Last Post: 7th Sep 2008, 18:57
