I am a noobie to .avi to dvd converting and authoring. I just recently converted my very first file. The file which is at 25 FPS is as u can tell PAL. Well on the guide I am following, it says that for sources at 23 FPS that they need to be converted to 29 FPS for TMPGEnc DVD Author, to be able to read them. But it doesnt mention anything about PAL or sources at 25 FPS.
My Question is will TMPGEnc DVD Author, accept my source at 25 FPS and author it correctly? (If not what do I need to do?)
Also is this video once bunred going to play ok on my stand alone DVD player?
O' the guide i am following is http://www.donstevenson.net/myguides/myguides.html
Yes, tmpgenc dvd author will accept 25 fps pal and author it correctly. All dvd author tools support pal and ntsc, but you cannot mix pal and ntsc on same dvd though(you can but it is not standard dvd-video).
It will play ok if your dvdplayer and tv supports pal...or if your dvdplayer can convert to NTSC for your TV.
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 06:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 23:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 05:53 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17
