Hope someone has a suggestion to my problem...
I accidentaly used ISO READ with decrypter for a DVD9... and on top of that it was put on my FAT32 drive.. So I have 3 files now.. the .mds file and the 2 split ISO files .I00 and .I01
My question is do you know of any way I can extract the contents of this ISO to my HD for further processing since I don't have the actual DVD at the moment? If I have done this on a NTFS drive I could just use ISOBUSTER as I have before to extract the contents... but when I use ISOBUSTER on the .I00 file it opens fine but when I extract it to the HD it will say it can't find all the files after about have way (because there in the .I01 file)..
Anyone know a way around this? Or am I screwed?
TIA. Spudz
Since a DVD9 is commercial only, and of course you own it since you ripped it, simply re-rip it. Get it back from whomever borrowed it from you.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
spudz2
if you can't get your dvd back from your friend borrow a usb drive from him(her) and transfer the 2 ISOs from your fat32 sys to your NTFS.
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 11:44 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
DVD Decrypter to ISO file - missing
By mkr10001 in forum DVD RippingReplies: 4Last Post: 5th Jan 2011, 17:55 -
Problems Creating ISO with DVD Fab Decrypter
By ViRaL1 in forum DVD RippingReplies: 1Last Post: 25th Jan 2009, 12:30 -
DVD-rebuilder issue: DVD9 to DVD5 not working
By Hurre in forum DVD RippingReplies: 13Last Post: 1st Apr 2008, 18:46
