how can i make a svcd with a DAT file that i downloaded from the net, must i convert it to mpg or just putt it in nero.
tia,
webadder
A dat file is usually a VCD file, you can use Nero directly to burn http://www.vcdhelp.com/nero.htm .
But if it is a svcd you exactly follow this (but skip the cutting part)
http://www.vcdhelp.com/bbmpegedit.htm
and then burn
http://www.vcdhelp.com/nerosvcd.htm
Player needs dat. file of avi files on disk
By karadeano in forum LinuxReplies: 9Last Post: 27th Jul 2015, 09:39 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 07:50 -
Advice needed on copying .dat files to DVD discs
By laval_ng in forum Video ConversionReplies: 17Last Post: 25th Oct 2008, 01:30 -
Do Divx dvd players play dat files?
By neo76 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 23rd Oct 2008, 22:27 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 08:03
