Ok, I have the LG GSA-4040 firmware A301, windows XP Pro, and have a slight problem
For some reason or other, when I insert a blank DVD (doesnt matter what type, I have tried every one except for +R) windows does not detect the media. Nero 6 doesnt detect it, dvd info, nothing. DVD info reports the drive as not ready when a blank DVD is inserted.
BTW, this all came about after I reformatted my computer. It also has difficulty reading DVD-RW's that I burned already
If anyone can help me out, that would be great!
Sounds like it may be an Aspi layer problem. Download ForceAspi, install it per the instructions and see if it works then.
I used Nero Info Tool, and found that there is no system ASPI, but there is a NeroASPI, version 2.0.1.56
I will try the new force ASPI... thanks
Problems Burning Movie Files onto blank Dvds-RW disks
By tealmarlin in forum Newbie / General discussionsReplies: 35Last Post: 1st Jan 2009, 11:18 -
Advice on blank DVDs
By didikai in forum Newbie / General discussionsReplies: 5Last Post: 28th May 2008, 22:30 -
Best burner for reading DVDs
By samijubal in forum DVD & Blu-ray WritersReplies: 15Last Post: 23rd May 2008, 11:21 -
Panasonic ES30V Stopped Reading blank discs
By newshoes in forum DVD & Blu-ray RecordersReplies: 5Last Post: 25th Oct 2007, 15:50 -
Burned DVD reading as a blank
By trailofdead in forum MediaReplies: 3Last Post: 17th Sep 2007, 12:12
