I have a divx video that will not convert. Video codec is Divx 5 and audio codec is AC3, I can watch the video fine, and the codecs are supported. When I try and convert with tmpge version 2.56, it starts and encodes about 1 min and the goes black for the rest. This video has been split to 2 cds and each are 715mb each, I have tried other encoders like winmpg, cce but none work, I have done a 100 or some movies before with no problems, but I am stumped, and help would be great, thanks.
Results 1 to 11 of 11
bigdave77 i beleive it is your audio, tmpgenc dose not supprot ac3. you need to convert it to a wav file.
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078 -
Ok,
I am using Avisynthv106 for frame serving, now I am getting errors like crazy.
error - (DirectShowSource: I can't determine the frame rate of the video; you must use the "fps" parameter G:\cabin\cabin2.avs, line1 )
what the hell is this? and how do I fix it? all of the avisynth links for info are broken.
This movie file will only play on the divx player, not media player. -
You could have at least listed your script. If you decide to do so, also list where you got the video from.
Hello.
How to convert TS into AI (DIVX)
By spaansebrabander in forum Video ConversionReplies: 2Last Post: 2nd Apr 2012, 05:38 -
Convert *.mkv to *.DivX
By Frizze in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2011, 00:35 -
Convert Divx
By didikai in forum Newbie / General discussionsReplies: 1Last Post: 21st Aug 2007, 13:22 -
Convert AVI to Divx
By shankie in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jul 2007, 02:52 -
How to Convert 1280*720 DivX to a less dimensions DivX
By firas_hashim in forum Video ConversionReplies: 9Last Post: 27th Jun 2007, 09:33
