I have solved many of my question with his program just with trying and testing. But there is one thing I can't find out. Is there anyway to have a videoclip between to menues? Like those you often find on commercial DVDs like Star Wars or Lord of the Rings?
If not, which program do I need to do this and still have the possibility to have motion menu and a introclip that comes before the first meny?
justice for all!! there is a free trial of this program. Try it and report back favourable or unfavourable.. will it do what you want??
Please find the FREE motion menu tutorials for Ulead DVD Workshop on the Web page at the following link:Originally Posted by HenrikSolberg
http://www.ulead.com/learning/dws.htm
There is also courseware available:
http://www.ulead.com/store/special/courseware_dws/runme.htm
There is also a book available:
http://www.ulead.com/partner/learntool/dwsbook/runme.htm
Yes - Ulead DVD Workshop will do what you have described.
Jerry Jones
http://www.jonesgroup.net -
I just saw at the DVDLab website that DVDLab can have transitions between menus! I´m closing up on my whish!!!
But i am still wondering if I can have a separate videclip (avi file) between two menus?
Maybe I can put this "Between clip" on a own menu (menu3) that I put between the two others (menu and menu2) thats after it is finished goes to the next menu (menu2)?
I belive this will work also?
Subtitle workshop, rewinding problem
By ~Fly in forum SubtitleReplies: 5Last Post: 13th Mar 2012, 13:36 -
Subtitle Workshop Overlapping Problem
By BradlyB in forum SubtitleReplies: 4Last Post: 11th Feb 2009, 21:37 -
DVD WORKSHOP 2 problem playing subtitles
By Bella in forum Newbie / General discussionsReplies: 8Last Post: 2nd Jun 2008, 12:17 -
DVD Workshop 2 audio problem
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 21st Feb 2008, 20:49 -
video preview problem with submagic and stubtitle workshop
By ecc in forum SubtitleReplies: 0Last Post: 27th Jan 2008, 03:48
