hi.
coul anyone tell me what the best avi to dvd converter is?
tmpg has trouble sometimes reading the sound.
thank's
There's no such thing.
Semantically there's no way anyone can help you. You said 'Best'. Do you mean final product quality wise? Do you insist that it take no more than 1 hour? Does it have to re-code to AC3 sound? Can it handle a DivX/XviD input? VBR Audio? Does it have to creat menues, Author? Burn?
You have to have specific requirements before you can get reccomendations. Insisting on animated menues eliminates many gret packages. At the same time, not being able to wait 20 hours for encoding could severly limit your options for 'perfect' output.
Besides, how many 1960's education videos or DV cam home movies do yuou want to do? These are the only forum acceptable AVI's you can convert to DVD :P
Most people can do extremely well with VDUB, TMPGEnc, and some basic Authoring application.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
An waht about home video? Analog caps to AVI or DV avi. Aren't you allowed to convert those to DVDOriginally Posted by Gazorgan
Depending on your budget, I think Canopus Procoder has a great looking interface, superb quality and an excellent PAL NTSC converter.
You can download a trial and there is great support on their forums. Try it out. However, you will not be able to edit your avi's with procoder, so I would suggest trying Vegas 4.0. It has great support for audio. Again a trial is available on their site.
You can go the cheaper route and download 40 different programs and spend ages learning each one of them.
There is no best program, just try all of them out and see what suits your needs.
tool to extract clip from a dvd to avi
By syeager in forum DVD RippingReplies: 2Last Post: 5th Apr 2009, 11:54 -
Your favorite DVD-to-AVI tool?
By shira in forum DVD RippingReplies: 3Last Post: 26th Jan 2008, 13:41 -
Whats the best tool to rip DVD and keep AR & have VBR MP3?
By incrediblej in forum DVD RippingReplies: 53Last Post: 19th Dec 2007, 19:00 -
Best tool for DV AVI -> DVD?
By timmus in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2007, 12:58 -
free tool for avi to dvd
By bmw2007 in forum Video ConversionReplies: 5Last Post: 29th May 2007, 17:30
