Is stereo AC3 exactly the same as MP2? I have just "converted" a 192k ac3 Dolby digital file to mp2( at 192k) and to my surprise its exactly the same size .. down to the last byte. Does this mean that ac3 is really just an extension to the mp2 standard to accommodate surround sound?. Really meaning that conversion of stereo ac3 to mp2 at the same bitrate should be merely a matter of rewriting the header record... and the file extension of course... I will try to get a byte comparison tool to see exactly what the difference are. Or is this just too simple to be true??![]()
Hi
No! - MP2 is just a compressed format whereas AC3 is a compressed format, with SurroundSound and created for use in large theaters (giving you the possibility to hear whispering and bombs exploding at the same time without getting your ears damaged)
Mp2 / Mp1 (.mp2, .mp1) - is the predecessor to Mp3, by today's standard mp2/mp1 compression no longer cuts the mustard (compression wise).
You can read more info here:
http://mornmist.2y.net/~blibbler/tutorial/basic/convertmpeg2.html
https://www.videohelp.com/forum/archive/t176533.html -
*.ac3 is not *.mp2. Both are official DVD audio formats. A realistic way of noting filesize differences would be to take a stereo *.wav file, then encode it first to a *.mp2, then same *.wav file to an *.ac3, using the same bitrate. Since these bitrates are fixed both resulting files will have the same, if not very close, filesizes. At high enough bitrates (about 256kb/s), both sound much the same to me. But the chances of getting played back correctly with a random DVD player is higher for *.ac3 than it is for *.mp2. There is one other convenience for *.ac3. Some will have their DVD player's digital outputs connected to their amplifiers that have built-in Dolby digital, DTS, and PCM decoders. Such an amplifier will immediately detect the Dolby digital bitstream, and decode and play it back properly. But a DVD with an *.mp2 track will just produce silence, unless that DVD player is set to "output *.mp2 (or MPEG, etc.) to *.pcm", at which, again the amplifier's decoder, picking up the PCM stream, will play it back so. There is only one receiver I am aware of that will decode and play back an *.mp2 or *.mp3 bitstream natively (without it having to be converted to *.pcm first), and that is by Harman-Kardon (forgot the model). Politiken's links are helpful.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
yes, they are completely different internally... oh well besweet is useful after all.. even if it has the worst interface in christendom (and other equally vaild religions).
Are there any tutorials to convert stereo MP3 to stereo AC3?
By rocky12 in forum AudioReplies: 10Last Post: 4th Sep 2011, 20:05 -
ac3 5.1 to aac stereo 2.0
By miss in forum AudioReplies: 4Last Post: 12th Dec 2009, 00:34 -
stereo loss after converting from wav to ac3
By Driber in forum AudioReplies: 8Last Post: 9th Sep 2009, 03:29 -
Upmix Stereo to AC3 5.1 Surround
By midders in forum DVB / IPTVReplies: 2Last Post: 10th Nov 2008, 22:12 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23
