Hi all,
I downloaded movie from the net for the first time and when I burt it, it was already in mpg format, into a vcd all went well and it plays on my DVD player, but the soundtrack is missing from the movie. The voice dialog and stuff is there but no music or other sounds that would normally be in the movie.
Is this normal, or is there something that I can do to fix the problem? The movie came out great but, not having the soundtrack is a real bummer.
I would appreciate any help.
Regards,
O2sly
<font size=-1>[ This Message was edited by: O2sly on 2001-10-11 15:10:18 ]</font>
the soundtrack is probably not there because it wasnt there in the source file, which means the only thing you can do is download another source file
The movie is the 'Fast And The Furious'. Very cool film. Got another question. When you burn a mpg, should you burn it as a VCD or a SVCD? Which one will come out better?
TIA
O2sly -
yeah okay, fast and the furious, btw i downloaded the same file there is no soundtrack with that source file, its got garbage resolution and it has sound pops in the backround. sorry bout that man, no soundtrack....
That's cool.
When downloading movies, should you d/l avi or mpg files?
Or does it not make any difference?
TIA
O2sly
Steps to repair a partially downloaded .avi that has a missing header.
By torrentcrazy in forum User guidesReplies: 12Last Post: 4th Feb 2015, 20:11 -
Missing audio in mpg files from Sony Camcorder in Final Cut and Quicktime
By Benhermies in forum MacReplies: 3Last Post: 2nd Feb 2011, 23:13 -
.mpg file suddenly missing first 30 seconds.
By John97 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2010, 16:17 -
mpg won't stream until the entire thing is downloaded.
By flycast in forum Video Streaming DownloadingReplies: 1Last Post: 19th Dec 2009, 23:23 -
DVD to Mpg - Missing Sections
By Tyler2000 in forum DVD RippingReplies: 1Last Post: 11th Dec 2008, 13:29
