I have Nero 6 with the latest updates and have been trying to capture MPEG2 Video from an AVER 203 capture card without success
The video plays fine in the window in Nero but when I start the capture the colour goes and green lines appear accross the images
I have tried every permutation possible (PAL) some are better than others but none give me satisfactory results
I am presently using the AVER capture progeam which is reasonable but would feel better using NERO which I use for the rest of the conversion
Can anyone help please
Phil
Results 1 to 10 of 10
Geesh! Nero is basically an application for putting data on writable CD and DVD media. Why do everyone insist on using it for things it's not good at? (Sorry for the rant.)
To put mildly - there are better applications for video capturing.
/Mats -
Thats fine and I accept that Nero is not good at everything but it should offer basic capture facilities. I'm not after bells and whistles but captures tinged in green with wavey lines dosn't come close
we don't all have a bottomless pit of money to keep buying software
I've have used the trial of TMPGENC to author and its far superior to Nero but i can't run to another 40 odd quid and therefore persist nero
Is there anyone who can offer me constructive advice on capturing using Nero -
Use Virtualdub for captures, it's free and amazingly useful for other things as well.don't all have a bottomless pit of money to keep buying software------------------------------------------------
Phillip
www.allaboutduncan.com
"Oh, they have the Internet on computers now."
I have two questions for you:
1. What equipment are you using to capture? This is very important as video capture is a very processor intensive item. A 1GHz machine would be very hard pressed to cope. It's especially important if your capture uses software encoding rather than hardware encoding.
2. Did you turn off the monitor function? This will take processing power that can better be used by the capture software.Artificial intelligence is no match for natural stupidity. -
And what capture card? The processor is certainly acceptable, but to repeat what I said earlier did you try with the video monitoring off?I have a AMD 2.0 ghz with 512 mb ram
XP Pro
Rest of system nearly newArtificial intelligence is no match for natural stupidity. -
Hmmmm! I had difficulty finding the data on that card as it isn't listed on this site. I also notice that Nero are talking about a major upgrade of their software for video handling due out in December so all I can really suggest is to wait until then and see if that sorts the problem (sorry!) alternatively may I suggest that you go to the Ulead web site and download their Moviefactory Trial software and see if that gives any better results.monitoring off and I am using an AVER 203 card
I'm sorry to say that you've gone beyond my abilities to help.Artificial intelligence is no match for natural stupidity.
Adobe Premier 5 AVI's won't load into Nero Vision 10
By rlarden in forum Video ConversionReplies: 1Last Post: 2nd Jul 2011, 05:43 -
NERO Vision Won't Produce DVD's
By Ensign in forum DVD RippingReplies: 11Last Post: 29th Sep 2009, 11:43 -
Nero won't burn video DVD
By solo_voyager in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 22:06 -
AVI won't run in Nero Vision Express 3
By loninappleton in forum Video ConversionReplies: 3Last Post: 9th Oct 2007, 14:33 -
Nero won't open .mp4 file
By ChickaJane in forum Video ConversionReplies: 8Last Post: 22nd Aug 2007, 00:38
