Hi Guys,
I found problem in audio sync with the video when making avi to mpg in TMPGEnc. Then I used GoldWave to separate the wav file and try again with TMPGEnc.
Now the result is, initial 40 mins of the avi is okay but after that, audio started to mismatch with video.
Please give me suggestion how to fix this problem.
Thanks a lot freinds.
Kodomali
sounds like bad frames...use virtual dub 1.45 ac3 to remove bad frames.
check the file using powerdvd....if sounds in sync...then your ok.
Audio/video Out of Synch in Converted AVI File
By Novice20 in forum Video ConversionReplies: 1Last Post: 31st Aug 2011, 03:10 -
Audio synch problems on an .avi file -noob
By ComicFan2 in forum ffmpegX general discussionReplies: 4Last Post: 18th Dec 2008, 13:47 -
Avi audio out of synch
By tumama in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2008, 15:37 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 13th Jan 2008, 00:47 -
AVI to MP4 Audio out of synch!! HELP!! DRIVING ME MAD!!!
By traqman in forum DVD RippingReplies: 7Last Post: 15th Jul 2007, 01:01
